[Proj] Netherlands RD (28992) to UTM Zone 32 (3044) produces shifted coordinates
Jelmer Baas baas at speerit.nl
Tue Jul 30 03:27:38 PDT 2013
Milo, Jan,
Thanks for the suggestions so far. I tried to rule out the NL->DE step by first going to WGS84.
Even this transformation doesn’t go the same as Oracle/MapInfo:
Point        135745.924    517131.216
Oracle  5.10275163084204   52.6413240233221
MapInfo 5.102751           52.641323
PostGis 5.10274900325229   52.6413367842089
PostGi2 5.10274907007772   52.6413367898401
DLL 4   5.10274904569186   52.6413366577093
DLL 3   5.102749003361     52.6413367848006
DLL 2   5.10274903201512   52.6413367357724
DLL 1   5.10274900325279   52.6413367843563
DLL ORG 5.10274909884125   52.6413367414033
I tried these projection strings:
+proj=sterea +lat_0=52.15616055555555 +lon_0=5.38763888888889 +k=0.9999079 +x_0=155000 +y_0=463000 +ellps=bessel +towgs84=565.417,50.3319,465.552,-0.398957,0.343988,-1.8774,4.0725 +units=m +no_defs  <>
+proj=sterea +lat_0=52.15616055555555 +lon_0=5.38763888888889 +k=0.999908 +x_0=155000 +y_0=463000 +ellps=bessel +towgs84=565.417,50.3319,465.552,-0.398957,0.343988,-1.8774,4.0725 +units=m +no_defs  no_defs <>
+proj=sterea +lat_0=52.156160556      +lon_0=5.387638889 +k=0.9999079 +x_0=155000 +y_0=463000 +towgs84=565.417,50.3319,465.552,-0.398957,0.343988,-1.8774,4.0725 +ellps=bessel +units=m +no_defs  no_defs <>
+proj=sterea +lat_0=52.15616055555555 +lon_0=5.38763888888889 +k=0.999908 +x_0=155000 +y_0=463000 +ellps=bessel  +units=m +towgs84=565.04,49.91,465.84,-0.409394387439237,0.359705195614311,-1.86849100035057,4.0772 +no_defs +to +proj=latlong +datum=WGS84
+proj=sterea +lat_0=52.15616055555555 +lon_0=5.38763888888889 +k=0.999908 +x_0=155000 +y_0=463000 +ellps=bessel +units=m +towgs84=565.2369,50.0087,465.658,-0.406857330322398,0.350732676542563,-1.8703473836068,4.0812 +no_defs <>
+proj=sterea +lat_0=52.15616055555555 +lon_0=5.38763888888889 +k=0.9999079 +x_0=155000 +y_0=463000 +ellps=bessel +towgs84=565.04,49.91,465.84,-1.9848,1.7439,-9.0587,4.0772 +units=m +no_defs
Met vriendelijke groet,
Jelmer Baas
Speer IT B.V.
From: proj-bounces at lists.maptools.org [mailto:proj-bounces at lists.maptools.org] On Behalf Of Milo van der Linden (gmail)
Sent: Tuesday, July 30, 2013 11:57
To: PROJ.4 and general Projections Discussions
Subject: Re: [Proj] Netherlands RD (28992) to UTM Zone 32 (3044) produces shifted coordinates
Hello Jelmer,
1. I would strongly advice to transform everything to wgs84 first.
2. wgs84 and etrs89 are based upon different spheroids/datums. Transforming from wgs84 TO etrs89 will not be correct if your etrs89 definition does not have +towgs84 defined. And by default I believe it isn't. Take a look at this ticket: http://trac.osgeo.org/proj/ticket/15 and see if it is of any help.
So, what I would do is:
epsg:28992 -> wgs84 (visual check) -> etrs89
Good luck!
2013/7/30 Jelmer Baas <baas at speerit.nl<mailto:baas at speerit.nl>>
Hello,
For a new project we need to convert coordinates from EPSG 28992 to EPSG 3044 with MapInfo, Oracle AND a few Proj.4 programs (PostGIS, a custom DLL, Proj4js). The problem we are having is that we're seeing some shifted coordinates.
First test point (in the Netherlands)
Origin               135745.924           517131.216
Proj4js              236345.39474983042   5839505.550959114
Postgis(1)           236345.390264227     5839505.55017783
Postgis(2)           236345.394817119     5839505.55055913
MapInfo              236345.47            5839504.058
CS2CSN               236345.39            5839505.55
DLL old(4)            236345.396465174     5839505.54496813
DLL new(3)           236345.390259674     5839505.55009311
Oracle               236345.49107424      5839504.12246656
Test point (in Germany)
Origin              254870.45            415123.56
MapInfo             350265.960           5731670.259
Postgis(1)          350263.4072329       5731667.880
Postgis(2)           350263.4132521       5731667.880
DLL new(3)           350263.407243136     5731667.88019826
DLL old(4)           350263.403514925     5731667.88565864
Oracle(5)           350265.967728329     5731670.33312477
CS2CS                350263.41            5731667.88 43.92     cs2cs +init=EPSG:28992 +to +init=EPSG:3044
It seems MapInfo and Oracle more-or-less agree, as do all Proj.4-based products. I don’t know which are “right”, meaning I also don’t know which ones are wrong – let alone find the fault.
Hopefully someone can help me with this problem, or at least point me in the right direction.
(1): "+proj=sterea +lat_0=52.15616055555555 +lon_0=5.38763888888889 +k=0.9999079 +x_0=155000 +y_0=463000 +ellps=bessel +towgs84=565.417,50.3319,465.552,-0.398957,0.343988,-1.8774,4.0725 +units=m +no_defs "
(2) Another server where I updated the spatial_ref_system: "+proj=sterea +lat_0=52.15616055555555 +lon_0=5.38763888888889 +k=0.9999079 +x_0=155000 +y_0=463000 +ellps=bessel +units=m +towgs84=565.2369,50.0087,465.658,-0.406857330322398,0.350732676542563,-1.8703473836068,4.0812 +no_defs no_defs"
(3) A custom built DLL for usage in VB6. "+proj=sterea +lat_0=52.15616055555555 +lon_0=5.38763888888889 +k=0.999908 +x_0=155000 +y_0=463000 +ellps=bessel +units=m +towgs84=565.2369,50.0087,465.658,-0.406857330322398,0.350732676542563,-1.8703473836068,4.0812 +no_defs <>"
(4) Same DLL. “+proj=sterea +lat_0=52.15616055555555 +lon_0=5.38763888888889 +k=0.9999079 +x_0=155000 +y_0=463000 +ellps=bessel +towgs84=565.417,50.3319,465.552,-0.398957,0.343988,-1.8774,4.0725 +units=m +no_defs  <>”
(5) select sdo_cs.transform(SDO_GEOMETRY('POINT(254870.45 415123.56)', 90112),25832)  from dual;
(5b) The Oracle definition contains some  tags I don’t see anywhere in Proj.4 (like the Bessel 1841 part):
PROJCS["Netherlands National System", GEOGCS [ "Netherlands Bessel", DATUM ["Netherlands Bessel", SPHEROID ["Bessel 1841", 6377397.155, 299.1528128]], PRIMEM [ "Greenwich", 0.000000 ], UNIT ["Decimal Degree", 0.01745329251994330]], PROJECTION ["Stereographic"], PARAMETER ["Scale_Factor", 0.999908], PARAMETER ["Central_Meridian", 5.387639], PARAMETER ["Latitude_Of_Origin", 52.156161], PARAMETER ["False_Easting", 155000.000000], PARAMETER ["False_Northing", 463000.000000], UNIT ["Meter", 1.000000000000]]
A side note is that transformation via my DLL doesn’t work properly (i.e., coordinates are shifted tens of meters), unless I *first* transform to WGS84 and then to 3044. I assume this is caused by an easy-to-fix error, but I don’t know what that is.
P.S.: PostGIS, Proj4JS and my epsg file are all up-to-date.
Thanks for any help,
With kind regards,
Jelmer Baas
Proj mailing list
Proj at lists.maptools.org<mailto:Proj at lists.maptools.org>
http://lists.maptools.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20130730/148ee05c/attachment.html>
