[Proj] Transformation of rotation
support.mn at elisanet.fi
Fri Sep 6 04:08:11 PDT 2013
Hello,
a simple plane rotation theta can be done using the following
formulas for each point:
xx = x*cos(theta) - y*sin(theta); // xx after, x before
yy = x*sin(theta) + y*cos(tjeta); // yy after, y before
see also:
http://en.wikipedia.org/wiki/Rotation_(mathematics)#Matrix_algebra
Janne.
Andre Joost [andre+joost at nurfuerspam.de] kirjoitti:
> Am 04.09.2013 16:23, schrieb support.mn at elisanet.fi:
> > Hello,
> > use 7 parameter datum shift - that include rotational parameters for each axis
> > in proj.4 you use towgs84 statement to define any datum shift.
> These shift parameters are applied to the axis at the center of the
> earth, and not on the surface where we normally use plane projected data
> in metres.
> Greetings,
> André Joost
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
More information about the Proj
