[Proj] Oblique Mercator problem?
Duncan Agnew
agnew at cahuilla.ucsd.edu
Fri Sep 6 15:58:36 PDT 2013
Under proj 4.7.1, if I input 0 0 to
invproj +proj=omerc +no_rot +lat_0=33 +lonc=-116 +alpha=45 +ellps=WGS84
I get 116dW 33dN as output. However, doing the same for proj4.8.0
gives
144d29'13.013"W 0d4'39.96"S
I've been using proj for some time; this has me baffled. (I should note
that the inverse and forward are consistent in both versions).
proj 4.7.1 was installed on Mac OSX 10.5, 4.8.0 on MacOSX 10.8
installed from MacPorts
Thanks
Duncan Agnew
dagnew at ucsd.edu
More information about the Proj
