[Proj] Beginner Question: Latitude/Longitude to x, y conversion - understanding output
AdamDynamic helloadamdynamic+proj4 at gmail.com
Mon Feb 24 05:30:12 PST 2014
Ah ok, thanks for that. Reading your answer, the notation makes a bit more
sense (a risk of using something you find on the internet without actually
understanding it)
> To output the map onto 900x1100 rectangle you have to scale the length
> and width of your projected map coordinates to 900 and 1100. And then
> you have to apply shift of origin of course.
Am I correct in thinking that as I have the latitude of true scale as the
Equator, then no shift of origin is required?
In terms of scaling the output, my understanding is that the 'corners' of a
projection based on latitude and longitude should be -180,-90 and 180,90 -
when I convert these values using the PyProj library I get values of 1E30
for each value (which seems to me clearly wrong). What is the best way to
scale the output in terms of min/max values (in 'pseudo-meters') for each
corner of my 900x1100 rectangle?
Thanks again for the help!
Adam
View this message in context: http://osgeo-org.1560.x6.nabble.com/Beginner-Question-Latitude-Longitude-to-x-y-conversion-understanding-output-tp5105455p5105524.html
Sent from the PROJ.4 mailing list archive at Nabble.com.
