[Proj] Beginner Question: Latitude/Longitude to x, y conversion - understanding output
Jose Gonçalves
jagoncal at gmail.com
Mon Feb 24 06:27:47 PST 2014
Adam
I think you have to change the order of your coordinates. The default input
for PROJ is (lon,lat) and the default output is (Easting,Northing).
I used PROJ in the command line to check.
You have done:
echo 51.5072 0.1275 | proj +proj=merc +a=6378137 +b=6378137
5733755.28 14193.25
and it should have been:
echo 0.1275 51.5072 | proj +proj=merc +a=6378137 +b=6378137
14193.24 6711506.71
The local deformation of lengths at latitude LAT is approximately 1/COS(LAT)
Regards
José Gonçalves
Call
Send SMS
Add to Skype
You'll need Skype CreditFree via Skype
2014-02-24 13:30 GMT+00:00 AdamDynamic <helloadamdynamic+proj4 at gmail.com>:
> Ah ok, thanks for that. Reading your answer, the notation makes a bit more
> sense (a risk of using something you find on the internet without actually
> understanding it)
> > To output the map onto 900x1100 rectangle you have to scale the length
> > and width of your projected map coordinates to 900 and 1100. And then
> > you have to apply shift of origin of course.
> Am I correct in thinking that as I have the latitude of true scale as the
> Equator, then no shift of origin is required?
> In terms of scaling the output, my understanding is that the 'corners' of a
> projection based on latitude and longitude should be -180,-90 and 180,90 -
> when I convert these values using the PyProj library I get values of 1E30
> for each value (which seems to me clearly wrong). What is the best way to
> scale the output in terms of min/max values (in 'pseudo-meters') for each
> corner of my 900x1100 rectangle?
> Thanks again for the help!
> Adam
> http://osgeo-org.1560.x6.nabble.com/Beginner-Question-Latitude-Longitude-to-x-y-conversion-understanding-output-tp5105455p5105524.html
> Sent from the PROJ.4 mailing list archive at Nabble.com.
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20140224/5e283397/attachment.html>
More information about the Proj
