[Proj] Mingw JNI build issue
Mark Christy mchristyuk at hotmail.com
Wed Feb 26 10:37:56 PST 2014
Hi Mike,
I did get it to build using Microsoft VC++ compiler (used the free express edition).
I had to modify the build scripts to get it to work, but I have at least ended up with a DLL that I can call from Java!
If you can hang on I'll upload my build scripts tomorrow when I'm back in the office.
Cheers
Mark
> Date: Wed, 26 Feb 2014 09:12:43 -0800
> From: mike.reynolds at aug-tech.co.uk
> To: proj at lists.maptools.org
> Subject: Re: [Proj] Mingw JNI build issue
> Hi.
> Have you managed to resolve this?
> I have been struggling to build Proj all day, and have now the exact same
> errors!
> I am also trying to use nmake with the makefile.vc - This does compile and
> create a proj.dll, but when I call any native functions from Java I get an
> UnsatisfiedLinkError, so something is missing!
> Cheers
> View this message in context: http://osgeo-org.1560.x6.nabble.com/Mingw-JNI-build-issue-tp5093816p5106172.html
> Sent from the PROJ.4 mailing list archive at Nabble.com.
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20140226/0e658eb1/attachment.html>
