[Proj] Build GDAL with NADSHIFT's
Even Rouault even.rouault at spatialys.com
Fri Nov 14 01:33:07 PST 2014
SriRam,
I had never saw a .prj with a METADATA node until now. Oh well... It just
seems to indicate NAD 83(2011) and the 4 first parameters of METDATA are the
bounding box in long/lat of validity for the SRS.
If you don't need a very accurate reprojection, you could just use -s_srs
"+proj=longlat +datum=NAD83" in ogr2ogr.
If you need very accurate reprojection (let's say error < 1 meter), you could
go with the tutorial at https://trac.osgeo.org/proj/wiki/HTDPGrids . But that
will be much more involved.
Even
> Hi
> I have a below .prj file
> GEOGCS["GCS_NAD_1983_2011",DATUM["D_NAD_1983_2011",SPHEROID["GRS_1980",6378
> 137.0,298.257222101]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199
> 433],METADATA["USA - CONUS and Alaska;
> PRVI",167.65,14.93,-63.89,74.71,0.0,0.0174532925199433,0.0,1511]]
> Can someone guide me how to project a Shape file with the below prj File.
> Testepsg is giving a failure for the above prj file.
> Let me know if anyone has used this earlier... To use the Conus and Alaska
> Parameters "Disclaimer: This message and any attachments contain
> information that may be RMSI Private Limited. confidential and/or
> privileged. If you are not the intended recipient (or authorized to
> receive for the intended recipient), and have received this message in
> error, any use, disclosure or distribution is strictly prohibited. If you
> have received this message in error, please notify the sender immediately
> by replying to the e-mail and permanently deleting the message from your
> computer and/or storage system" http://www.rmsi.com
http://www.spatialys.com
