[Proj] Proj 4.9.1RC4 Released
Frank Warmerdam
warmerdam at pobox.com
Tue Mar 3 08:30:24 PST 2015
Howard,
I would suggest moving these out of testvarious into a test_flakey set and
then moving forward. I don't want to lose them entirely but they aren't
worth getting tied in knots about.
Best regards,
Frank
On Sat, Feb 28, 2015 at 12:58 PM, Sebastiaan Couwenberg <sebastic at xs4all.nl>
wrote:
> On 02/28/2015 09:45 PM, Howard Butler wrote:
> > This issue is holding me up from motioning to release 4.9.1.
> > If people do not think this issue warrants holding things up,
> > I will simply remove this test and wait for someone with experience
> > with both the healpix coordinate tests and signed zeros to fix things up.
> Disabling the three troublesome tests reported in #255 is reasonable in
> my opinion. I'm not sure to what extent you want to remove the test,
> removing testvarious entirely seems a bit much.
> I've ignore the failing tests in the Debian package build for the time
> being, to prevent the small number of architecture specific test
> failures from failing the entire build.
> Kind Regards,
> Bas
> GPG Key ID: 4096R/6750F10AE88D4AF1
> Fingerprint: 8182 DE41 7056 408D 6146 50D1 6750 F10A E88D 4AF1
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
I set the clouds in motion - turn up | Frank Warmerdam,
and watch the world go round - Rush | Geospatial Software Developer
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20150303/ac9b1ce3/attachment.html>
More information about the Proj
