[Proj] Proj 4.9.1RC4 Released
nicolas david
ericnico.david at gmail.com
Tue Mar 3 13:56:39 PST 2015
Hi Charles
Being the guy behind proj4-cmake old repository I supect to be also the guy
who wrote this warning.
If a remember well is due to the fact that nad2nad and nad2bin include
"project.h" and not "proj_api.h". So as on windows dll only include
(export) symbol defined in proj_api.h ( more precisely in proj.def) I was
thinking that when you include "project.h" it's better to link to static
lib in order to have all symbol defined.
I'm note 100% of this fact and I could be wrong but I think it was the
explanation of this warning. Looking deeper in the code it seems that
nad2bin only use struct defined in project.h and not function so it could
work.
Nicolas DAVID
2015-03-03 15:34 GMT+01:00 Charles Karney <charles.karney at sri.com>:
> To stay consistent with our previous (4.8.0) build of proj on Windows,
> I'd like to build proj as a shared library. However this triggers a
> warning
> nad2nad can't be build with a DLL proj4 library you need a static lib
> Can anyone explain the origin of this warning? I note that the nad2nad
> executable gets created OK with the shared library and that it can
> report its usage when given no arguments.
> On 2015-02-24 16:28, Howard Butler wrote:
> >> On Feb 23, 2015, at 8:04 AM, Sebastiaan Couwenberg <sebastic at xs4all.nl>
> wrote:
> >>>> https://trac.osgeo.org/proj/ticket/255
> >>> I propose we dial back the precision on the test as Frank suggested.
> >> That's probably the best short term solution, yes.
> > I have issued RC4 to address this issue.
> > http://download.osgeo.org/proj/proj-4.9.1RC4.tar.gz
> > Howard
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20150303/8336b524/attachment.html>
More information about the Proj
