[Proj] proj 4.9.1 released
Howard Butler
howard at hobu.co
Tue Mar 10 12:44:19 PDT 2015
All,
proj 4.9.1 is released as approved by the MetaCRS list. It cumulates a number of bug fixes and small updates, and it went through five release candidates before being declared final.
http://download.osgeo.org/proj/proj-4.9.1.tar.gz
Thanks,
Howard
> o 4.9.0RC2 release was abandoned because it was not promoted in a
> timely fashion. Subsequent maintenance of tickets has continued,
> and a new 4.9.1 release was issued in its place.
> o Implement inverse solution for Winkel Tripel from Drazan Tutic #250
> o More CMake configuration tweaks. The CMake configuration is probably
> not at feature parity with the autotools builds at this point but it
> is converging #256
> o Tweak initialization ordering around setlocal which may have caused
> issues #237
> o Support out-of-tree autoconf builds more completely #247
> o Fix NaN handling by geod_inverse and geod_polygon_addedge #251 & #253
> o Update config.sub and config.guess #257
> o Adapt Charles Karney's CMake patches for smoother build #258
> o Define default PROJ_LIB location for CMake compilation #261
> o Fix Windows compilation on PJ_aitoff.c
> o Align CMake SOVERSION with autotools #263
> o Regenerate nad/epsg with GDAL r28536 to avoid precision loss in TOWGS84
> parameters, e.g. on Amersfoort / RD EPSG:4289 (#260)
> o Add CMake project-config.cmake scripts (#264 from Charles Karney)
> o Dial back test sensitivity #255
More information about the Proj
