[Proj] proj 4.9.1 released
Charles Karney
charles.karney at sri.com
Tue Mar 10 13:32:46 PDT 2015
Thanks Howard! Don't forget to update the download links on
http://trac.osgeo.org/proj/wiki/WikiStart
On 2015-03-10 15:44, Howard Butler wrote:
> All,
> proj 4.9.1 is released as approved by the MetaCRS list. It cumulates a number of bug fixes and small updates, and it went through five release candidates before being declared final.
> http://download.osgeo.org/proj/proj-4.9.1.tar.gz
> Thanks,
> Howard
>> o 4.9.0RC2 release was abandoned because it was not promoted in a
>> timely fashion. Subsequent maintenance of tickets has continued,
>> and a new 4.9.1 release was issued in its place.
>> o Implement inverse solution for Winkel Tripel from Drazan Tutic #250
>> o More CMake configuration tweaks. The CMake configuration is probably
>> not at feature parity with the autotools builds at this point but it
>> is converging #256
>> o Tweak initialization ordering around setlocal which may have caused
>> issues #237
>> o Support out-of-tree autoconf builds more completely #247
>> o Fix NaN handling by geod_inverse and geod_polygon_addedge #251 & #253
>> o Update config.sub and config.guess #257
>> o Adapt Charles Karney's CMake patches for smoother build #258
>> o Define default PROJ_LIB location for CMake compilation #261
>> o Fix Windows compilation on PJ_aitoff.c
>> o Align CMake SOVERSION with autotools #263
>> o Regenerate nad/epsg with GDAL r28536 to avoid precision loss in TOWGS84
>> parameters, e.g. on Amersfoort / RD EPSG:4289 (#260)
>> o Add CMake project-config.cmake scripts (#264 from Charles Karney)
>> o Dial back test sensitivity #255
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
Charles Karney <charles.karney at sri.com>
SRI International, Princeton, NJ 08543-5300
Tel: +1 609 734 2312
Fax: +1 609 734 2662
More information about the Proj
