[Proj] proj 4.9.1 released
Richard Greenwood
richard.greenwood at gmail.com
Tue Mar 10 17:40:58 PDT 2015
Nice work Howard, et al.
On Tue, Mar 10, 2015 at 2:32 PM, Charles Karney <charles.karney at sri.com>
wrote:
> Thanks Howard! Don't forget to update the download links on
> http://trac.osgeo.org/proj/wiki/WikiStart
> On 2015-03-10 15:44, Howard Butler wrote:
> > All,
> > proj 4.9.1 is released as approved by the MetaCRS list. It cumulates a
> number of bug fixes and small updates, and it went through five release
> candidates before being declared final.
> > http://download.osgeo.org/proj/proj-4.9.1.tar.gz
> > Thanks,
> > Howard
> >> o 4.9.0RC2 release was abandoned because it was not promoted in a
> >> timely fashion. Subsequent maintenance of tickets has continued,
> >> and a new 4.9.1 release was issued in its place.
> >> o Implement inverse solution for Winkel Tripel from Drazan Tutic #250
> >> o More CMake configuration tweaks. The CMake configuration is probably
> >> not at feature parity with the autotools builds at this point but it
> >> is converging #256
> >> o Tweak initialization ordering around setlocal which may have caused
> >> issues #237
> >> o Support out-of-tree autoconf builds more completely #247
> >> o Fix NaN handling by geod_inverse and geod_polygon_addedge #251 & #253
> >> o Update config.sub and config.guess #257
> >> o Adapt Charles Karney's CMake patches for smoother build #258
> >> o Define default PROJ_LIB location for CMake compilation #261
> >> o Fix Windows compilation on PJ_aitoff.c
> >> o Align CMake SOVERSION with autotools #263
> >> o Regenerate nad/epsg with GDAL r28536 to avoid precision loss in
> TOWGS84
> >> parameters, e.g. on Amersfoort / RD EPSG:4289 (#260)
> >> o Add CMake project-config.cmake scripts (#264 from Charles Karney)
> >> o Dial back test sensitivity #255
> > Proj mailing list
> > Proj at lists.maptools.org
> > http://lists.maptools.org/mailman/listinfo/proj
> SRI International, Princeton, NJ 08543-5300
> Tel: +1 609 734 2312
> Fax: +1 609 734 2662
> Proj mailing list
Richard W. Greenwood, PLS
www.greenwoodmap.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20150310/cd343977/attachment.html>
More information about the Proj
