[Proj] [gdal-dev] EPSG:6933
Even Rouault
even.rouault at spatialys.com
Tue Nov 10 05:33:49 PST 2015
Ramona,
Long answer:
This CRS probably didn't exist in the EPSG database v8.5 that was used the
last time the proj/GDAL derived EPSG database was generated. And I see that
the ellipsoidal Lamber Cylindrical Equal Area projection method 9835 was also
unknown of GDAL. I've fixed GDAL to recognize it so next time the proj/GDAL
EPSG database is regenerated EPSG:6933 will be there.
Short answer:
use "+proj=cea +lon_0=0 +lat_ts=30 +x_0=0 +y_0=0 +datum=WGS84 +no_defs"
instead of EPSG:6933 in the meantime.
Best regards,
Even
Le mardi 10 novembre 2015 13:45:02, Ramona Deck a écrit :
> Hello,
> I want to use Soil Moisture data from the SMOS-project which have EPSG
> code: 6933. I try to use gdalwarp for warping the file into EPSG:32632.
> This is the code I use:
> >gdalwarp -s_srs EPSG:6933 -t_srs EPSG:32632 -tr 100 100
> >subset_SM_OPER_MIR_CLF3MA_20140101T000000_20140131T235959_270_001_7.tif
> >SM.tif
> Unfortunately I get an error message:
> ERROR 6: EPSG PCS/GCS code 6933 not found in EPSG support files. Is this a
> valid EPSG coordinate system? ERROR 1: Translating source or target SRS
> failed:
> EPSG:6933
> So it seems that gdal can't find the EPSG code 6933.
> Is there anything I can do for solving the problem?
> It would be great to get help. Thank you in advance!
> Best regards,
http://www.spatialys.com
More information about the Proj
