[Proj] [gdal-dev] EPSG:6933
Mike Toews mwtoews at gmail.com
Tue Nov 10 12:56:00 PST 2015
On 11 November 2015 at 02:33, Even Rouault <even.rouault at spatialys.com> wrote:
> Long answer:
> This CRS probably didn't exist in the EPSG database v8.5 that was used the
> last time the proj/GDAL derived EPSG database was generated. And I see that
> the ellipsoidal Lamber Cylindrical Equal Area projection method 9835 was also
> unknown of GDAL. I've fixed GDAL to recognize it so next time the proj/GDAL
> EPSG database is regenerated EPSG:6933 will be there.
Are EPSG:6931 and EPSG:6932 supported as well?
The EASE-Grid Data website [1] indicates they are supported by GDAL
with correct version of PROJ.4 (4.8.0), but I can only get the
original EASE-Grid codes working with gdalsrsinfo / ImportFromEPSG.
[1] https://nsidc.org/data/ease/versions.html
