[Proj] [gdal-dev] EPSG:6933
Even Rouault even.rouault at spatialys.com
Tue Nov 10 13:04:38 PST 2015
Le mardi 10 novembre 2015 21:56:00, Mike Toews a écrit :
> On 11 November 2015 at 02:33, Even Rouault <even.rouault at spatialys.com>
wrote:
> > Long answer:
> > This CRS probably didn't exist in the EPSG database v8.5 that was used
> > the last time the proj/GDAL derived EPSG database was generated. And I
> > see that the ellipsoidal Lamber Cylindrical Equal Area projection method
> > 9835 was also unknown of GDAL. I've fixed GDAL to recognize it so next
> > time the proj/GDAL EPSG database is regenerated EPSG:6933 will be there.
> Are EPSG:6931 and EPSG:6932 supported as well?
Not with current distributed GDAL/proj EPSG database. Should come with a next
update.
> The EASE-Grid Data website [1] indicates they are supported by GDAL
> with correct version of PROJ.4 (4.8.0)
With the important note
Note1: Use these ProjectedCRS Codes for EPSG Version 8.6 or later.
Note2: GDAL tools built with the correct version of PROJ4 will work on the
EASE-Grid 2.0 projections with PROJ4 strings even if it's built with EPSG
Codes earlier than 8.6.
So if you update the GDAL csv files or add a definition in epsg.wkt, that will
work. It is "just" a matter of updating the database.
http://www.spatialys.com
