[Proj] Proj 4.9.3 RC3 Released
Even Rouault
even.rouault at spatialys.com
Thu Sep 1 07:47:22 PDT 2016
Le lundi 29 août 2016 21:00:54, Howard Butler a écrit :
> Proj 4.9.3 RC3 is now available. The following updates were made since RC2:
> - self-test is opt-in rather than opt-out (means smaller binaries by
> default) https://github.com/OSGeo/proj.4/pull/405 - whitespace
> normalization https://github.com/OSGeo/proj.4/pull/402 - healpix init
> https://github.com/OSGeo/proj.4/pull/399
> - Times projection implementation https://github.com/OSGeo/proj.4/pull/400
> - GIGS test update https://github.com/OSGeo/proj.4/pull/386
> Should no significant issues be found in the next few days, I will put
> forward this release to the MetaCRS committee for a release vote.
I just tested 4.9.3RC3 against GDAL -trunk. No build issue. A few failed tests
to adjust probably due to the switch to etmerc for utm.
Even
http://www.spatialys.com
More information about the Proj
