[Proj] Proj 4.9.3 RC3 Released
Even Rouault even.rouault at spatialys.com
Thu Sep 1 08:12:35 PDT 2016
Le jeudi 01 septembre 2016 16:47:22, Even Rouault a écrit :
> Le lundi 29 août 2016 21:00:54, Howard Butler a écrit :
> > Proj 4.9.3 RC3 is now available. The following updates were made since
> > RC2:
> > - self-test is opt-in rather than opt-out (means smaller binaries by
> > default) https://github.com/OSGeo/proj.4/pull/405 - whitespace
> > normalization https://github.com/OSGeo/proj.4/pull/402 - healpix init
> > https://github.com/OSGeo/proj.4/pull/399
> > - Times projection implementation
> > https://github.com/OSGeo/proj.4/pull/400 - GIGS test update
> > https://github.com/OSGeo/proj.4/pull/386
> > Should no significant issues be found in the next few days, I will put
> > forward this release to the MetaCRS committee for a release vote.
> I just tested 4.9.3RC3 against GDAL -trunk. No build issue. A few failed
> tests to adjust probably due to the switch to etmerc for utm.
OK, 2 of the 3 failed tests were due to me having forgotten to install the
'conus' grid from the extra grid package, and the last one was indeed due to
UTM now relying on etmerc and its super wide validity range. So everything's
OK from my side.
> Even
http://www.spatialys.com
