[Proj] Receiving "pj_transform(): Unknown error" while trying to use cs2cs from rpoly to utm
Kristian Evers kreve at sdfe.dk
Wed Sep 28 00:56:35 PDT 2016
I had a quick look in Yang, Snyder & Tobler and it should be fairly easy to implement the inverse projection. I've created a ticket for it: https://github.com/OSGeo/proj.4/issues/420
Feel free to submit a pull request!
/Kristian
> -----Oprindelig meddelelse-----
> Fra: proj-bounces at lists.maptools.org [mailto:proj-
> bounces at lists.maptools.org] På vegne af John Buonagurio
> Sendt: 27. september 2016 23:16
> Til: PROJ.4 and general Projections Discussions
> Emne: Re: [Proj] Receiving "pj_transform(): Unknown error" while trying to
> Hi,
> PROJ.4 only supports the forward transformation (from lon/lat to projected).
> The inverse transformation isn't implemented unfortunately for rectangular
> polyconic:
> <https://github.com/OSGeo/proj.4/blob/master/src/PJ_rpoly.c#L12>
> ("no inv.")
> Has anyone looked into this? The inverse is described in Yang/Snyder/Tobler.
> John
> From: proj-bounces at lists.maptools.org [mailto:proj-
> bounces at lists.maptools.org] On Behalf Of Resnick, Jessica
> Sent: Tuesday, September 27, 2016 2:06 PM
> To: proj at lists.maptools.org
> Subject: [Proj] Receiving "pj_transform(): Unknown error" while trying to
> Hi All,
> I am trying to convert some points from rpoly to utm. I have tried typing
> Cartesian coordinates and cartographic coordinates and both result in the
> error:
> <cs2cs>: while processing file: <stdin>, line 1
> pj_transformation(): Unknown error
> For some reason it works correctly if I go from utm to rpoly, but that is not
> what I am trying to do.
> Here is my code:
> cs2cs +proj=rpoly +lat_ts=25.066667 +lon_0=-80.636667 +ellps=bessel +to
> +proj=utm +zone 17 +ellps=WGS84
> I tried inputting:
> -80.4666667 +24.983333333
> and got:   *                  *       0.00
> 17151.59  2799896.42
> and got:    *                 *       0.00
> Can anyone tell me what I am doing wrong?
> Thanks!
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
