[Proj] Receiving "pj_transform(): Unknown error" while trying to use cs2cs from rpoly to utm
John Buonagurio
jbuonagurio at exponent.com
Wed Sep 28 10:39:15 PDT 2016
Thanks, my thoughts as well. The calculations for this projection are very similar to the regular (American) polyconic.
I'll give it a shot - working on implementing the inverse on the sphere. Will submit via pull request.
John
-----Original Message-----
From: proj-bounces at lists.maptools.org [mailto:proj-bounces at lists.maptools.org] On Behalf Of Kristian Evers
Sent: Wednesday, September 28, 2016 3:57 AM
To: PROJ.4 and general Projections Discussions <proj at lists.maptools.org>
Subject: Re: [Proj] Receiving "pj_transform(): Unknown error" while trying to use cs2cs from rpoly to utm
I had a quick look in Yang, Snyder & Tobler and it should be fairly easy to implement the inverse projection. I've created a ticket for it: https://urldefense.proofpoint.com/v2/url?u=https-3A__github.com_OSGeo_proj.4_issues_420&d=DQIGaQ&c=t0wRGL5ICVzH157W8C8Wew&r=Q-Rs-yPWbL0-v_m_Ov9CS1uGraVrKdE4mvUkBfZ3rWE&m=9qi7q5QoQWxg6vZjCV32eGaFCcF3h2BpKvbInYryzts&s=kz8sB_TLq3wDwp1Gvttw4ZxIq8a-L40nxugvAoI-Lps&e=
Feel free to submit a pull request!
/Kristian
> -----Oprindelig meddelelse-----
> Fra: proj-bounces at lists.maptools.org [mailto:proj-
> bounces at lists.maptools.org] På vegne af John Buonagurio
> Sendt: 27. september 2016 23:16
> Til: PROJ.4 and general Projections Discussions
> Emne: Re: [Proj] Receiving "pj_transform(): Unknown error" while trying to
> Hi,
> PROJ.4 only supports the forward transformation (from lon/lat to projected).
> The inverse transformation isn't implemented unfortunately for rectangular
> polyconic:
> <https://urldefense.proofpoint.com/v2/url?u=https-3A__github.com_OSGeo_proj.4_blob_master_src_PJ-5Frpoly.c-23L12&d=DQIGaQ&c=t0wRGL5ICVzH157W8C8Wew&r=Q-Rs-yPWbL0-v_m_Ov9CS1uGraVrKdE4mvUkBfZ3rWE&m=9qi7q5QoQWxg6vZjCV32eGaFCcF3h2BpKvbInYryzts&s=0CIu0APRS-wSnhnKpZRmHYh2htrzQNE_AQAz-wYulAg&e= >
> ("no inv.")
> Has anyone looked into this? The inverse is described in Yang/Snyder/Tobler.
> John
> bounces at lists.maptools.org] On Behalf Of Resnick, Jessica
> Sent: Tuesday, September 27, 2016 2:06 PM
> To: proj at lists.maptools.org
> Subject: [Proj] Receiving "pj_transform(): Unknown error" while trying to
> Hi All,
> I am trying to convert some points from rpoly to utm. I have tried typing
> Cartesian coordinates and cartographic coordinates and both result in the
> error:
> <cs2cs>: while processing file: <stdin>, line 1
> pj_transformation(): Unknown error
> For some reason it works correctly if I go from utm to rpoly, but that is not
> what I am trying to do.
> Here is my code:
> cs2cs +proj=rpoly +lat_ts=25.066667 +lon_0=-80.636667 +ellps=bessel +to
> +proj=utm +zone 17 +ellps=WGS84
> I tried inputting:
> -80.4666667 +24.983333333
> and got: * * 0.00
> 17151.59 2799896.42
> and got: * * 0.00
> Can anyone tell me what I am doing wrong?
> Thanks!
> Proj mailing list
> Proj at lists.maptools.org
> https://urldefense.proofpoint.com/v2/url?u=http-3A__lists.maptools.org_mailman_listinfo_proj&d=DQIGaQ&c=t0wRGL5ICVzH157W8C8Wew&r=Q-Rs-yPWbL0-v_m_Ov9CS1uGraVrKdE4mvUkBfZ3rWE&m=9qi7q5QoQWxg6vZjCV32eGaFCcF3h2BpKvbInYryzts&s=5kUXaRL5BcgHzRyfMSdYtVwoAvruAaxQYJiUhoCw6zA&e=
Proj mailing list
More information about the Proj
