[Proj] Special(User Defined?) Coordinate?
Jose Gonçalves jagoncal at gmail.com
Mon Aug 7 14:54:12 PDT 2017
Hi
You can use command gdal_translate with option -a_ullr to replace the upper
left and lower right coordinates. See the usage in
http://www.gdal.org/gdal_translate.html
Regards
Jose' Gonçalves
2017-08-07 9:53 GMT+01:00 원영진 <icetiger at nate.com>:
> Hello
> I am novice in Proj4 and English
> in My TIF Data File
> Coordinate is 0~3600 (West-East), and 0~1800 (South-North)
> I want to use EPSG 4326 (WGS84)
> but I can not assign source Projection
> So, I can not use GDALWarp.exe Command Line Tool
> Now I move every Cells one by one method
> Can I Make Proj4 String?
> Best Regards
> ICE
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20170807/0251cea5/attachment.html>
