[Proj] WG: VB Net wrapper Proj.4
stevejking stevejking at talktalk.net
Tue Aug 8 14:21:59 PDT 2017
RĂ¼esch Thomas wrote
> Hi Bas
> Thank you for the fast answer.
> I got the file, which uses proj 4.4.6. with 32Bit
> Is the a newer Version of the wrapper dll or one with 64 bit support?
> Best regards
> Thomas
After a bit of Googling, I've updated and compiled Eric's VB api wrapper
against the current Proj 4.9.3. But strange the dll no longer seems to need
Proj.dll, so maybe I did something wrong? The files are here:
https://1drv.ms/f/s!AvBQ7Pt73oO6ghpCVRs1YmTNyVd_
64 and 32 bit. I've only tested the 32bit dll.
Regards
Steve
View this message in context: http://osgeo-org.1560.x6.nabble.com/WG-VB-Net-wrapper-Proj-4-tp5320211p5330866.html
Sent from the PROJ.4 mailing list archive at Nabble.com.
