[Proj] (moved to) https://github.com/OSGeo/proj-datumgrid
Greg Troxel
gdt at lexort.com
Mon Dec 18 17:28:25 PST 2017
Even Rouault <even.rouault at spatialys.com> writes:
>> Ah sorry for reinventing the wheel, we should probably just
>> push your repo
> Done:
What is the plan for how these bits are used?
It seems obvious to me that they should be released with version numbers
and enough of a packaging system that they can install into
${prefix}/share/proj/? or something, so that packaging systems can make
packages (one, separate?), for installation by use by end users.
But I suspect this bias to packaging may be less obvious to those who
are close to proj, especially if they themselves always run proj from
sources.
Desc: not available
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20171218/4eaf890f/attachment.sig>
More information about the Proj
