[Proj] (moved to) https://github.com/OSGeo/proj-datumgrid
Sebastiaan Couwenberg
sebastic at xs4all.nl
Mon Dec 18 22:29:15 PST 2017
On 12/19/2017 02:28 AM, Greg Troxel wrote:
> Even Rouault <even.rouault at spatialys.com> writes:
>>> Ah sorry for reinventing the wheel, we should probably just
>>> push your repo
>> Done:
> What is the plan for how these bits are used?
Primarily to produce the proj-datumgrid archives alongside proj.
> It seems obvious to me that they should be released with version numbers
> and enough of a packaging system that they can install into
> ${prefix}/share/proj/? or something, so that packaging systems can make
> packages (one, separate?), for installation by use by end users.
For now the proj build system is still expected to install the gridshift
files. This could possibly be separated in the future.
> But I suspect this bias to packaging may be less obvious to those who
> are close to proj, especially if they themselves always run proj from
> sources.
Kind Regards,
Bas
GPG Key ID: 4096R/6750F10AE88D4AF1
Fingerprint: 8182 DE41 7056 408D 6146 50D1 6750 F10A E88D 4AF1
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20171219/52cb6b77/attachment.sig>
More information about the Proj
