[Proj] (moved to) https://github.com/OSGeo/proj-datumgrid
Kristian Evers
kreve at sdfe.dk
Tue Dec 19 12:28:46 PST 2017
I’ve opened a pull request [0] with a few updates to the README and a new file listing all the including grid files, their sources and licenses. Please have a look at it and see if I’ve got everything right. If there’s something I’ve forgot please let me know.
/Kristian
[0] https://github.com/OSGeo/proj-datumgrid/pull/1
On 19 Dec 2017, at 07:29, Sebastiaan Couwenberg <sebastic at xs4all.nl<mailto:sebastic at xs4all.nl>> wrote:
On 12/19/2017 02:28 AM, Greg Troxel wrote:
Even Rouault <even.rouault at spatialys.com<mailto:even.rouault at spatialys.com>> writes:
Ah sorry for reinventing the wheel, we should probably just
push your repo
Done:
What is the plan for how these bits are used?
Primarily to produce the proj-datumgrid archives alongside proj.
It seems obvious to me that they should be released with version numbers
and enough of a packaging system that they can install into
${prefix}/share/proj/? or something, so that packaging systems can make
packages (one, separate?), for installation by use by end users.
For now the proj build system is still expected to install the gridshift
files. This could possibly be separated in the future.
But I suspect this bias to packaging may be less obvious to those who
are close to proj, especially if they themselves always run proj from
sources.
Kind Regards,
Bas
GPG Key ID: 4096R/6750F10AE88D4AF1
Fingerprint: 8182 DE41 7056 408D 6146 50D1 6750 F10A E88D 4AF1
Proj mailing list
Proj at lists.maptools.org<mailto:Proj at lists.maptools.org>
http://lists.maptools.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20171219/9a49e3cf/attachment.html>
More information about the Proj
