[Proj] +towgs84 approximation error
Jochem jochem.lesparre at kadaster.nl
Wed Mar 22 18:34:32 PDT 2017
Hi Stefanos,
I have coordinates in an old national grid and a new national grid. Both
grids have TM projections on the international Hayfort ellipsoid. Both grids
have 7 parameter transformations to WGS84 defined by the government but not
published in EPSG. I want to do:
cs2cs +init=mygrids:old +to +init=mygrids:new -f %.4f <old_coords.txt
>new_coords.txt
What I need is exactly what I explained in my first email: a 7 parameter
transformation without approximation error of 4 cm (this error is a bias,
not a standard deviation) in the formulas.
Regards, Jochem
View this message in context: http://osgeo-org.1560.x6.nabble.com/towgs84-approximation-error-tp5313738p5313766.html
Sent from the PROJ.4 mailing list archive at Nabble.com.
