[Proj] +towgs84 approximation error
Clifford J Mugnier cjmce at lsu.edu
Wed Mar 22 18:53:41 PDT 2017
How many coordinate pairs?  For that level of desired accuracy you're going to need more than 100 points.  Is that reasonable?
Sent from Cliff Mugnier's iPhone
> On Mar 22, 2017, at 8:34 PM, Jochem <jochem.lesparre at kadaster.nl> wrote:
> Hi Stefanos,
> I have coordinates in an old national grid and a new national grid. Both
> grids have TM projections on the international Hayfort ellipsoid. Both grids
> have 7 parameter transformations to WGS84 defined by the government but not
> published in EPSG. I want to do:
> cs2cs +init=mygrids:old +to +init=mygrids:new -f %.4f <old_coords.txt
>> new_coords.txt
> What I need is exactly what I explained in my first email: a 7 parameter
> transformation without approximation error of 4 cm (this error is a bias,
> not a standard deviation) in the formulas.
> Regards, Jochem
> View this message in context: http://osgeo-org.1560.x6.nabble.com/towgs84-approximation-error-tp5313738p5313766.html
> Sent from the PROJ.4 mailing list archive at Nabble.com.
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
