[Proj] +towgs84 approximation error
Jochem
jochem.lesparre at kadaster.nl
Wed Mar 22 19:20:03 PDT 2017
Cliff,
The transformation has been estimated by performing static GPS observations
on about 12 points of the old triangulation frame. Ofcourse these parameters
are not at 1 mm precise but more like a few cm. However, these parameters
have been in use for some time now. Therefore these parameters are
conventional* parameters and I need to keep to that convention within 1 mm.
I do not know the number of points to be transformed, the entire digital map
of a small country (probably a few million).
*) Van der Marel, 2016
<http://www.citg.tudelft.nl/fileadmin/Faculteit/CiTG/Over_de_faculteit/Afdelingen/Afdeling_Geoscience_and_Remote_Sensing/Study/CTB3310_TerrestrialReferenceSystems_TRS_2-1a.pdf>
page 33-34
Regards, Jochem
View this message in context: http://osgeo-org.1560.x6.nabble.com/towgs84-approximation-error-tp5313738p5313775.html
Sent from the PROJ.4 mailing list archive at Nabble.com.
More information about the Proj
