[Proj] Time for a new release?
Even Rouault even.rouault at spatialys.com
Fri Nov 10 05:37:26 PST 2017
Janne,
Please stop your uninformed ranting. If you had followed, even by a tiny bit, the activity of
the project over the last year, you'd have seen that a ton of great work has been done.
We have repeated  for years that if you don't want new developements or bug fixes, stay
with old versions. Or make your own fork: you're apparently much smarter and have more
wisdom than the rest of us, poor brain-less folks.
But worse, you are,- and unfortunately this is not the first time -, publicly insulting qualified
developers and scientists that are Kristian Evers and Thomas Knudsen. This is not acceptable,
and we don't want to see this happening again.
Proj.4 as part of the MetaCRS initiative of OSGeo is subject to
http://www.osgeo.org/code_of_conduct
Read it carefully, and apply it. Thanks
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20171110/972d2a5b/attachment.html>
