[Proj] Time for a new release?
    Huw James
    huwejames at gmail.com
    Fri Nov 10 06:23:34 PST 2017
Dear all,
I'd like to publicly thank Kristian, Thomas, Even and all others that have
contributed to keeping PROJ.4 alive and well maintained.
Sometimes there are questions from very inexperienced users and sometimes
by users who do not understand datums and projections very well. Such
questions have been answered with great kindness and patience which is also
to be admired.
Let's all of us remain kind and patient please.
Thank you all again. You're performing at a very standard in every way.
Huw James
On Fri, Nov 10, 2017 at 7:37 AM, Even Rouault <even.rouault at spatialys.com>
wrote:
> Janne,
> Please stop your uninformed ranting. If you had followed, even by a tiny
> bit, the activity of the project over the last year, you'd have seen that a
> ton of great work has been done.
> We have repeated for years that if you don't want new developements or bug
> fixes, stay with old versions. Or make your own fork: you're apparently
> much smarter and have more wisdom than the rest of us, poor brain-less
> folks.
> But worse, you are,- and unfortunately this is not the first time -,
> publicly insulting qualified developers and scientists that are Kristian
> Evers and Thomas Knudsen. This is not acceptable, and we don't want to see
> this happening again.
> Proj.4 as part of the MetaCRS initiative of OSGeo is subject to
> http://www.osgeo.org/code_of_conduct
> Read it carefully, and apply it. Thanks
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20171110/9ce7feaf/attachment.html>
More information about the Proj
