[Proj] Pixel area errors
strebe at aol.com
strebe at aol.com
Mon Nov 20 21:32:42 PST 2017
Ken,
For any projection, at any point that is not a singularity, you compute the Jacobian matrix at that point. From the Jacobian, you can determine the scale factor in any direction. The Jacobian is a convenient way to compute the Tissot indicatrix, which is the measure of distortion at the point.
See, for example:
Piotr H. Laskowski (1989), “The Traditional and Modern Look at Tissot’s Indicatrix”,
The American Cartographer, 16:2, 123-133
http://dx.doi.org/10.1559/152304089783875497
If you only work in one projection, you can probably simplify quite a bit. For example, on spherical Mercator, the scale factor s is
s = sec φ
where φ is the latitude.
This is purely local distance I’m talking about here, which seems to be what you want.
Regards,
— daan Strebe
-----Original Message-----
To: proj <proj at lists.maptools.org>
Sent: Mon, Nov 20, 2017 9:14 am
Subject: [Proj] Pixel area errors
Dear List,
I've just learned that GRASS has a function to provide the true scale for a given cell. From this, I can determine the map projection error.
My understanding is that for a given projection, the "lat_ts" term of the proj4 string describing the projection is where 1 m in GRASS is actually 1 m. Elsewhere, errors grow. I'd like to track these.
I asked the following on the GRASS list and was advised that this list might be a better place to ask:
Is the scale error only in longitude and never in latitude? Or can it be in both? Is there a way to find the error for a length error rather than an area error? Specifically, for a vector line with an arbitrary heading?
Thank you,
-k.
Proj mailing list
Proj at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20171121/1e219643/attachment.html>
More information about the Proj
