[Proj] Several versions of the EGM96 grid
Kristian Evers kreve at sdfe.dk
Thu Oct 5 02:56:50 PDT 2017
Andre,
Well that clears that up. I see that you have already create a ticket with the OSGeo4W guys. Thanks!
/Kristian
-----Oprindelig meddelelse-----
Fra: proj-bounces at lists.maptools.org [mailto:proj-bounces at lists.maptools.org] På vegne af Andre Joost
Sendt: 5. oktober 2017 11:38
Til: proj at lists.maptools.org
Emne: Re: [Proj] Several versions of the EGM96 grid
Am 05.10.2017 um 11:31 schrieb Andre Joost:
> If you look at:
> http://download.osgeo.org/proj/vdatum/egm96_15/
> You see a egm96_15-incorrect.gtx from 2010, and a "correct" one from 2014.
> OSGEO4W64 has the one from 2010.
And the related ticket is .....:
https://github.com/OSGeo/proj.4/issues/126
So soemone should update the OSGEO4W file as well.
Greetings,
André Joost
Proj mailing list
Proj at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/proj
