[Proj] Several versions of the EGM96 grid
Joaquim Luis
jmfluis at gmail.com
Thu Oct 5 03:58:01 PDT 2017
And why still use the EGM96 instead of at least the EGM2008?
Joaquim
Sent from my iDedo
No dia 05/10/2017, às 10:56, Kristian Evers <kreve at sdfe.dk> escreveu:
> Andre,
> Well that clears that up. I see that you have already create a ticket with the OSGeo4W guys. Thanks!
> /Kristian
> -----Oprindelig meddelelse-----
> Fra: proj-bounces at lists.maptools.org [mailto:proj-bounces at lists.maptools.org] På vegne af Andre Joost
> Sendt: 5. oktober 2017 11:38
> Til: proj at lists.maptools.org
> Emne: Re: [Proj] Several versions of the EGM96 grid
>> Am 05.10.2017 um 11:31 schrieb Andre Joost:
>> If you look at:
>> http://download.osgeo.org/proj/vdatum/egm96_15/
>> You see a egm96_15-incorrect.gtx from 2010, and a "correct" one from 2014.
>> OSGEO4W64 has the one from 2010.
> And the related ticket is .....:
> https://github.com/OSGeo/proj.4/issues/126
> So soemone should update the OSGEO4W file as well.
> Greetings,
> André Joost
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
> Proj mailing list
More information about the Proj
