[Proj] Failed to initialize PROJ.4 with "..."
Chris Marsh
chris.marsh at usask.ca
Fri Oct 13 15:00:22 PDT 2017
Thanks for the thoughts.
Yes ERROR 6 is the GDAL wrapper error.
On the computer that 'works':
cs2cs +proj=latlon +datum=WGS84 +to +proj=aea +lat_1=20 +lat_2=60 +lat_0=40
+lon_0=-96 +ellps=GRS80 +units=m +no_defs
-135.197151 60.52163
-2102114.41 2828965.44 0.00
On the computer that doesn't
./cs2cs +proj=latlon +datum=WGS84 +to +proj=aea +lat_1=20 +lat_2=60
+lat_0=40 +lon_0=-96 +ellps=GRS80 +units=m +no_defs
So that seems like that works....
Would this point to GDAL being 100% the culprit?
Cheers
Chris
On 13 October 2017 at 21:23, Kristian Evers <kreve at sdfe.dk> wrote:
> Chris,
> The "ERROR: 6" is GDAL. I am not sure if GDAL is forwarding the error code
> from PROJ.4, although I don't think so since PROJ.4 error codes are
> negative. This is why I want you to reproduce the problem just by using
> PROJ.4.
> Try running "cs2cs +proj=latlon +datum=WGS84 +to +proj=aea +lat_1=20
> +lat_2=60 +lat_0=40 +lon_0=-96 +ellps=GRS80 +units=m +no_defs" on the
> computer in question. If it fails the problem is definitely related to
> PROJ.4.
> Kristian
> ________________________________________
> Fra: proj-bounces at lists.maptools.org [proj-bounces at lists.maptools.org]
> på vegne af stevejking [stevejking at talktalk.net]
> Sendt: 13. oktober 2017 22:41
> Til: proj at lists.maptools.org
> Emne: Re: [Proj] Failed to initialize PROJ.4 with "..."
> Kristian,
> Is that a Proj4 error code?
> The Proj4 codes seem more specific. My reference says code 6 is "effective
> eccentricity = 1."
> Is it even a GDAL error code?
> Steve
> Kristian Evers-2 wrote
> > Chris,
> > It would be beneficial if you could try to reproduce this problem just
> > using PROJ.4 and a few simple coordinates. Either on the command line
> with
> > a call to cs2cs or by a small C program. I tried initialising the
> > projection with a recent version of PROJ.4 without problems and I can't
> > see any obvious problem in the proj string. It is likely that if this
> > indeed is a bug in PROJ.4 that it has already been fixed.
> > /Kristian
> > Fra:
> > proj-bounces at .maptools
> > ] på vegne af Chris Marsh [
> > chris.marsh@
> > Sendt: 13. oktober 2017 17:56
> > Til:
> > proj at .maptools
> > Emne: [Proj] Failed to initialize PROJ.4 with "..."
> > Hi,
> > ERROR 6: Failed to initialize PROJ.4 with `+proj=aea +lat_1=20 +lat_2=60
> > +lat_0=40 +lon_0=-96 +x_0=0 +y_0=0 +ellps=GRS80 +towgs84=0,0,0,0,0,0,0
> > +units=m +no_defs'.
> > ...Cheers
> > Chris
> > Proj mailing list
> > Proj at .maptools
> > http://lists.maptools.org/mailman/listinfo/proj
> Sent from: http://osgeo-org.1560.x6.nabble.com/PROJ-4-f3840930.html
> Proj mailing list
> Proj at lists.maptools.org
> Proj mailing list
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20171013/4d7d2b3b/attachment.html>
More information about the Proj
