[Proj] Failed to initialize PROJ.4 with "..."
Even Rouault
even.rouault at spatialys.com
Fri Oct 13 15:32:16 PDT 2017
On vendredi 13 octobre 2017 15:56:09 CEST Chris Marsh wrote:
> Hi,
> I'm using GDAL (and by extension proj.4) to reproject a set of WGS84
> coordinates to North America Albers Conic Conformal.
> I originally posted this to the GDAL list, however it seems like this may
> be entirely a Proj.4 problem.
> On all but 1 computer I run my code on, this works as expected. However,
> when trying to run on one of Compute Canada's newest machines, I get the
> error
How did you build GDAL on that machine, --with-static-proj4 ?
If not, the issue is probably that you have libproj.so.XXXX installed, but not
libproj.so
Even
http://www.spatialys.com
More information about the Proj
