[Proj] Failed to initialize PROJ.4 with "..."
Chris Marsh chris.marsh at usask.ca
Fri Oct 13 15:35:38 PDT 2017
I did not build with that option, however I have my build libproj.so in my
LD_LIBRARY_PATH
Chris Marsh
PhD Candidate
chrismarsh.ca
121 Research Drive
University of Saskatchewan
On 13 October 2017 at 16:32, Even Rouault <even.rouault at spatialys.com>
wrote:
> On vendredi 13 octobre 2017 15:56:09 CEST Chris Marsh wrote:
> > Hi,
> > I'm using GDAL (and by extension proj.4) to reproject a set of WGS84
> > coordinates to North America Albers Conic Conformal.
> > I originally posted this to the GDAL list, however it seems like this may
> > be entirely a Proj.4 problem.
> > On all but 1 computer I run my code on, this works as expected. However,
> > when trying to run on one of Compute Canada's newest machines, I get the
> > error
> How did you build GDAL  on that machine, --with-static-proj4 ?
> If not, the issue is probably that you have libproj.so.XXXX installed, but
> not
> libproj.so
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20171013/96ce549f/attachment.html>
