[Proj] Proj Digest, Vol 157, Issue 4
Melita Kennedy
mkennedy2 at earthlink.net
Fri Oct 13 16:17:02 PDT 2017
Chris,
Do you still get the error message if you change the output '+ellps=grs80' to '+datum=wgs84'? You also omitted the '+towgs84' parameter when you tested using cs2cs. The grs80 and wgs84 flattening are almost equal so I wonder if GDAL is doing some calculation connected to the '+towgs84' parameter using the grs80 and wgs84 ellipsoids incorrectly.
Melita
-----Original Message-----
>Date: Fri, 13 Oct 2017 22:00:22 +0000
>From: Chris Marsh <chris.marsh at usask.ca>
>Subject: Re: [Proj] Failed to initialize PROJ.4 with "..."
>To: PROJ.4 and general Projections Discussions
> <proj at lists.maptools.org>
>Hi,
>Thanks for the thoughts.
>Yes ERROR 6 is the GDAL wrapper error.
>On the computer that 'works':
>cs2cs +proj=latlon +datum=WGS84 +to +proj=aea +lat_1=20 +lat_2=60 +lat_0=40
>+lon_0=-96 +ellps=GRS80 +units=m +no_defs
>-135.197151 60.52163
>-2102114.41 2828965.44 0.00
>On the computer that doesn't
>./cs2cs +proj=latlon +datum=WGS84 +to +proj=aea +lat_1=20 +lat_2=60
>+lat_0=40 +lon_0=-96 +ellps=GRS80 +units=m +no_defs
>So that seems like that works....
>Would this point to GDAL being 100% the culprit?
>Cheers
>Chris
>On 13 October 2017 at 21:23, Kristian Evers <kreve at sdfe.dk> wrote:
>> Chris,
>> The "ERROR: 6" is GDAL. I am not sure if GDAL is forwarding the error code
>> from PROJ.4, although I don't think so since PROJ.4 error codes are
>> negative. This is why I want you to reproduce the problem just by using
>> PROJ.4.
>> Try running "cs2cs +proj=latlon +datum=WGS84 +to +proj=aea +lat_1=20
>> +lat_2=60 +lat_0=40 +lon_0=-96 +ellps=GRS80 +units=m +no_defs" on the
>> computer in question. If it fails the problem is definitely related to
>> PROJ.4.
>> Kristian
>> ________________________________________
>> Fra: proj-bounces at lists.maptools.org [proj-bounces at lists.maptools.org]
>> på vegne af stevejking [stevejking at talktalk.net]
>> Sendt: 13. oktober 2017 22:41
>> Til: proj at lists.maptools.org
>> Emne: Re: [Proj] Failed to initialize PROJ.4 with "..."
>> Kristian,
>> Is that a Proj4 error code?
>> The Proj4 codes seem more specific. My reference says code 6 is "effective
>> eccentricity = 1."
>> Is it even a GDAL error code?
>> Steve
>> Kristian Evers-2 wrote
>> > Chris,
>> > It would be beneficial if you could try to reproduce this problem just
>> > using PROJ.4 and a few simple coordinates. Either on the command line
>> with
>> > a call to cs2cs or by a small C program. I tried initialising the
>> > projection with a recent version of PROJ.4 without problems and I can't
>> > see any obvious problem in the proj string. It is likely that if this
>> > indeed is a bug in PROJ.4 that it has already been fixed.
>> > /Kristian
>> > Fra:
>> > proj-bounces at .maptools
>> > ] p? vegne af Chris Marsh [
>> > chris.marsh@
>> > Sendt: 13. oktober 2017 17:56
>> > Til:
>> > proj at .maptools
>> > Emne: [Proj] Failed to initialize PROJ.4 with "..."
>> > Hi,
>> > ERROR 6: Failed to initialize PROJ.4 with `+proj=aea +lat_1=20 +lat_2=60
>> > +lat_0=40 +lon_0=-96 +x_0=0 +y_0=0 +ellps=GRS80 +towgs84=0,0,0,0,0,0,0
>> > +units=m +no_defs'.
>> > ...Cheers
>> > Chris
>> > _______________________________________________
>> > Proj mailing list
>> > Proj at .maptools
>> > http://lists.maptools.org/mailman/listinfo/proj
More information about the Proj
