[Proj] Code style in Proj
Kristian Evers kreve at sdfe.dk
Mon Apr 30 06:00:01 PDT 2018
Kurt,
I think it looks good. I tried compiling the code and again I had the problem with declarations like
XY xy = {0.0, 0.0};
I’ve fixed those in a fork of your gist. See revision 2 in [0] for a proposed solution that I think
is in line with your ideas
I like how you’ve separated includes from the standard library on the PROJ internal includes. On
a related note (for those who don’t already know) I have recently introduced the proj_math.h
header which is intended as a PROJ replacement of math.h. proj_math.h’s purpose in life is to
make sure that we can use C99 math functions on systems where they are not available.
proj_math.h includes math.h and defines functions such as isnan() and hypot(). This way they
can be used as you would on a C99-compatible system as long as proj_math.h is included.
See revision 3 in [0].
Would you be willing to write up a simple style guide for PROJ based on the ideas you have presented in
this thread?
/Kristian
[0] https://gist.github.com/kbevers/17ec703942646e401b28a0975b28771d/revisions
On 24 Apr 2018, at 12:05, Mateusz Loskot <mateusz at loskot.net<mailto:mateusz at loskot.net>> wrote:
On 24 April 2018 at 11:45, Thomas Knudsen <knudsen.thomas at gmail.com<mailto:knudsen.thomas at gmail.com>> wrote:
In C too, but since C99.
AFAIK this only applies to the "for (int i = 0;  i < n; i++)" syntax.
while (...) {
   int i = 123, j = 345;
   k = i + j;
has been correct (and imho, preferable) syntax since K&R C
AFAIK, it's about compound statement.
C89 requires declaration at the top of blocks, while C99 lifts that:
$ cat test.c
int main()
   int i = 0;
   while (i < 10)
       int j = 345;
       i = i + j;
       int z = 0;
       z = 1;
   int x = 1;
$ gcc -std=c89 -pedantic test.c
test.c: In function ‘main’:
test.c:14:5: warning: ISO C90 forbids mixed declarations and code
[-Wdeclaration-after-statement]
    int x = 1;
$ gcc -std=c99 -pedantic test.c
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
Proj mailing list
Proj at lists.maptools.org<mailto:Proj at lists.maptools.org>
http://lists.maptools.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20180430/028fab85/attachment.html>
