[Proj] Code style in Proj
Thomas Knudsen
knudsen.thomas at gmail.com
Mon Apr 30 06:44:25 PDT 2018
I think line 116 in Kristian's revised version misses an "else": Gnu C, and
probably many other compilers, accepts "naked" compound statements, but I
do not think it is in accordance with the C89 standard
2018-04-30 15:00 GMT+02:00 Kristian Evers <kreve at sdfe.dk>:
> Kurt,
> I think it looks good. I tried compiling the code and again I had the
> problem with declarations like
> XY xy = {0.0, 0.0};
> I’ve fixed those in a fork of your gist. See revision 2 in [0] for a
> proposed solution that I think
> is in line with your ideas
> I like how you’ve separated includes from the standard library on the PROJ
> internal includes. On
> a related note (for those who don’t already know) I have recently
> introduced the proj_math.h
> header which is intended as a PROJ replacement of math.h. proj_math.h’s
> purpose in life is to
> make sure that we can use C99 math functions on systems where they are not
> available.
> proj_math.h includes math.h and defines functions such as isnan() and
> hypot(). This way they
> can be used as you would on a C99-compatible system as long as proj_math.h
> is included.
> See revision 3 in [0].
> Would you be willing to write up a simple style guide for PROJ based on
> the ideas you have presented in
> this thread?
> /Kristian
> [0] https://gist.github.com/kbevers/17ec703942646e401b28a0975b2877
> 1d/revisions
> On 24 Apr 2018, at 12:05, Mateusz Loskot <mateusz at loskot.net> wrote:
> On 24 April 2018 at 11:45, Thomas Knudsen <knudsen.thomas at gmail.com>
> wrote:
> In C too, but since C99.
> AFAIK this only applies to the "for (int i = 0; i < n; i++)" syntax.
> while (...) {
> int i = 123, j = 345;
> k = i + j;
> has been correct (and imho, preferable) syntax since K&R C
> AFAIK, it's about compound statement.
> C89 requires declaration at the top of blocks, while C99 lifts that:
> $ cat test.c
> int main()
> int i = 0;
> while (i < 10)
> int j = 345;
> i = i + j;
> int z = 0;
> z = 1;
> int x = 1;
> $ gcc -std=c89 -pedantic test.c
> test.c: In function ‘main’:
> test.c:14:5: warning: ISO C90 forbids mixed declarations and code
> [-Wdeclaration-after-statement]
> int x = 1;
> $ gcc -std=c99 -pedantic test.c
> Best regards,
> Mateusz Loskot, http://mateusz.loskot.net
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
> Proj mailing list
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20180430/9a438ee4/attachment.html>
More information about the Proj
