[Proj] Few danish PROJ definitions are missing
Kristian Evers kreve at sdfe.dk
Fri Aug 10 00:14:29 PDT 2018
Evan,
Thanks for reporting this.
On 10 Aug 2018, at 08:21, Evan Haahr Hansen, LIFA A/S <eha at LIFA.DK<mailto:eha at LIFA.DK>> wrote:
Hi all
We are about to implement the PROJ libraries in our applications but it seems that a few Danish PROJ definitions are missing:
Awesome!
DNN  - We know that code says that it is “historical” but when you work with old maps you still need it
System City Ring – near Copenhagen
FK89 (EPSG code 3173) – for the Faroe Islands
These are all work in progress. I’m adding issues to the tracker [0], that should help prioritize them.
I also think that there is a small error in the PROJ definition for UTM29N_FVR09. In the last part of the definition there is a reference to FO:UTM32N. Shouldn’t it be FO:UTM29N (which is defined in the line above) ?
Fixed [1][2]. This will be released alongside PROJ 5.2 September 1st.
Kristian
[0] https://github.com/NordicGeodesy/NordicTransformations/issues<https://github.com/NordicGeodesy/NordicTransformations/issues?q=is:issue+is:open+sort:updated-desc>
[1] https://github.com/NordicGeodesy/NordicTransformations/commit/a8f15c0423d9410f494db665297cbe1571424b1d
[2] https://github.com/OSGeo/proj-datumgrid/commit/67ad31e00db720f5344499d67fc5bd6627229772
Med venlig hilsen
Ingeniør
<image001.png>
T
6313 6800
D
6313 6852
W
www.lifa.dk<http://www.lifa.dk/>
M
Vi tilbyder interne og eksterne kurser. Du kan finde mere information i vores kursuskalender<https://www.lifa.dk/kursuskalender>
<image002.png><https://www.linkedin.com/company/lifa-a-s/>
Følg os på LinkedIn og læs de seneste nyheder fra LIFA A/S Landinspektører
Proj mailing list
Proj at lists.maptools.org<mailto:Proj at lists.maptools.org>
http://lists.maptools.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20180810/99a56aaf/attachment.html>
