[Proj] Confusion about Docker images
Even Rouault
even.rouault at spatialys.com
Mon Aug 13 07:49:55 PDT 2018
Thanks Howard ! Things are much clearer now.
Even
> On 8/11/18 10:11 AM, Even Rouault wrote:
> > Hi,
> > I see in https://hub.docker.com/u/osgeo/
> > that they are osgeo/proj.4 and osgeo/proj Docker images.
> > I had some issues to understand what they are / how different they are.
> > It seems that osgeo/proj is the result of the automated build of master
> > with https://github.com/OSGeo/proj.4/blob/master/Dockerfile
> > The leading "# osgeo/proj.4" comment in that file should likely be renamed
> > "# osgeo/proj" to avoid the confusion
> > Whereas osgeo/proj.4 is pulled by travis/docker.sh and used by travis/
> > build_docs.sh to build the website documentation.
> > - What is the source of this osgeo/proj.4 Docker image ?
> It was one that I was maintaining locally. I have pushed it to
> https://github.com/OSGeo/proj.4/blob/master/docs/docbuild/Dockerfile
> > - Shouldn't that be renamed to osgeo/proj-doc-deps or somthing like that
> > to
> > avoid confusion ?
> done. osgeo/proj-docs
> > - and its description at https://hub.docker.com/r/osgeo/proj.4/ "A Proj.4
> > image with a full set of grid files" is also misleading.
> I removed this image to eliminate confusion. If anyone was actually
> using it, they'll be able to find the osgeo/proj, which is built
> automatically with every commit from ./Dockerfile in the source tree. I
> have refreshed it to use Ubuntu 18.04.
> Sorry for the confusion.
> Howard
http://www.spatialys.com
More information about the Proj
