[Proj] Convert a planetographic latitude to a planetocentric latitude
Jean-Christophe Malapert
jcmalapert at gmail.com
Sat Aug 18 12:30:22 PDT 2018
Hello,
I am quite new to the use of Proj4. I spend a few days to investigate a
problem but I have no clue how to solve it. So that's why I am writing to
you. I hope you will be able to answer me.
I have 2 different CRS for the same planet : one is based on the sphere (CRS1,
radius=3396190) and another one based on the ellipse (CRS2, a=3396190
b=3376200). When I give the (longitude, latitude) in the CRS1 as inputs (
planetocentric latitude = planetographic latitude), I want to get the
planetographic latitude expressed in the CRS2. So, I wrote the following
command :
cs2cs +proj=latlong +a=3396190 +b=3396190 +to +proj=latlong +a=3396190
+b=3376200
> 0 80 # longitude latitude
I get the following result "0dE 80dN 0.000" . The latitude should change
but it is not the case !!! Should I add some options ? Is it possible to
do this kind of transformation with proj4 ?
Thanks in advance,
Jean-Christophe
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20180818/193b1a66/attachment.html>
More information about the Proj
