[Proj] converting WGS84/ETRS89 to ITM/OSGM15
Even Rouault
even.rouault at spatialys.com
Wed Aug 22 03:26:24 PDT 2018
Alain,
> Doing the same way you try
> this (with proj program) I can’t get the correct use of the GeoidGrid.
> Why????
proj is the historical command line utility at the time where the library only
handled cartographic projections, but not datum transformations hence it
ignores +towgs84, +nadgrids, +geoidgrids. For the later, you need to use cs2s
Even
http://www.spatialys.com
More information about the Proj
