[Proj] converting WGS84/ETRS89 to ITM/OSGM15
Elmir Jagudin elmir.jagudin at gmail.com
Thu Aug 23 01:45:27 PDT 2018
On Wed, Aug 22, 2018 at 12:27 PM Even Rouault <even.rouault at spatialys.com>
wrote:
> Alain,
> > Doing the same way you try
> > this (with proj program) I can’t get the correct use of the GeoidGrid.
> > Why????
> proj is the historical command line utility at the time where the library
> only
> handled cartographic projections, but not datum transformations hence it
> ignores +towgs84, +nadgrids, +geoidgrids. For the later, you need to use
> cs2s
> Even
Ok, this explains why +geoidgrids never worked.
It's a bit of a pitfall, maybe a warning should be in order?
/Elmir
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20180823/b77ebf65/attachment.html>
