[Proj] Proj-5.0.0 cct path to gridfiles
Kristian Evers kristianevers at gmail.com
Mon Feb 19 14:03:03 PST 2018
HI Steve,
If you start by setting the PROJ_LIB variable you should be fine:
	set PROJ_LIB=C:\proj-5.0.0-RC3\proj-5.0.0\nad
	cct +proj=…
At least that should let you work around this for now. You can also define it properly in the Windows settings as a persistent environment variable if you don’t want to set it on the command line each time you open a new terminal-window.
I will investigate why cct doesn’t find the grids. It seems odd to me.
/Kristian
> On 19 Feb 2018, at 22:49, stevejking <stevejking at talktalk.net> wrote:
> Hi
> When using cs2cs I don’t need to specify the path to gridfile (eg nadgrids
> and geoidgrids).
> But with the new cct I find I get “cct: Bad transformation arguments -
> (failed to load datum shift file)” unless I give full path.
> Using Windows 7 64 bit
> Proj installed to
> C:\proj-5.0.0RC3\proj-5.0.0
> Grids present in nad sub folder
> Grids Also copied in
> C:\proj\nad
> Regards
> Steve
> Sent from: http://osgeo-org.1560.x6.nabble.com/PROJ-4-f3840930.html
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
