[Proj] Proj-5.0.0 cct path to gridfiles
Thomas Knudsen knudsen.thomas at gmail.com
Mon Feb 19 14:12:40 PST 2018
Steve,
Could you provide a few samples of full actual invocations, indicating
which succeed and which fail?
Also please check whether Kristan's suggestion of setting PROJ_LIB helps.
/Thomas
Den 19. feb. 2018 11.04 PM skrev "Kristian Evers" <kristianevers at gmail.com>:
> HI Steve,
> If you start by setting the PROJ_LIB variable you should be fine:
>         set PROJ_LIB=C:\proj-5.0.0-RC3\proj-5.0.0\nad
>         cct +proj=…
> At least that should let you work around this for now. You can also define
> it properly in the Windows settings as a persistent environment variable if
> you don’t want to set it on the command line each time you open a new
> terminal-window.
> I will investigate why cct doesn’t find the grids. It seems odd to me.
> /Kristian
> > On 19 Feb 2018, at 22:49, stevejking <stevejking at talktalk.net> wrote:
> > Hi
> > When using cs2cs I don’t need to specify the path to gridfile (eg
> nadgrids
> > and geoidgrids).
> > But with the new cct I find I get “cct: Bad transformation arguments -
> > (failed to load datum shift file)” unless I give full path.
> > Using Windows 7 64 bit
> > Proj installed to
> > C:\proj-5.0.0RC3\proj-5.0.0
> > Grids present in nad sub folder
> > Grids Also copied in
> > C:\proj\nad
> > Regards
> > Steve
> > Sent from: http://osgeo-org.1560.x6.nabble.com/PROJ-4-f3840930.html
> > Proj mailing list
> > Proj at lists.maptools.org
> > http://lists.maptools.org/mailman/listinfo/proj
> Proj mailing list
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20180219/1cbe1c43/attachment.html>
