[Proj] Proj-5.0.0 cct path to gridfiles
Kristian Evers kreve at sdfe.dk
Tue Feb 20 03:02:22 PST 2018
Steve,
I have looked into this a bit further and I still don't understand what's going on. Can you describe in more details how you've compiled and installed PROJ? I need a complete walkthrough of the commands you've issued to come the conclusion that cct doesn't find the grids.
Thanks,
Kristian
-----Oprindelig meddelelse-----
Fra: proj-bounces at lists.maptools.org [mailto:proj-bounces at lists.maptools.org] På vegne af stevejking
Sendt: 20. februar 2018 08:48
Til: proj at lists.maptools.org
Emne: Re: [Proj] Proj-5.0.0 cct path to gridfiles
Hi Thomas & Kristian,
Thanks for the replies.
Yes, setting PROJ-LIB works as a temporary fix.
I've uploaded the cs2cs and cct strings, grid files and a couple of
coordinate pairs. In a bit of a hurry this morning.
https://1drv.ms/f/s!AvBQ7Pt73oO6iGeGDh4livK-EKAJ Hope that helps.
The cs2cs one works fine, the cct one has the above error, but works if the
full path to gridfiles is given.
Steve
Sent from: http://osgeo-org.1560.x6.nabble.com/PROJ-4-f3840930.html
Proj mailing list
Proj at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/proj
