[Proj] Pipeline +init files, inverse
stevejking stevejking at talktalk.net
Wed Feb 21 13:18:00 PST 2018
Is it possible to use a +init pipeline file in reverse?
For example, with some explanation from Kristian, I now have two
transformations:
# OSGB1936 to ETRS89(2)
<7709-3D>                  -t0 +proj=pipeline \
                      +step +proj=tmerc +lat_0=49 +lon_0=-2 +k=0.9996012717
+x_0=400000 +y_0=-100000 +ellps=airy +inv \
                      +step +proj=vgridshift
+grids=OSGM15_GTX_OSGBtoGRS80.gtx +inv \
                      +step +proj=hgridshift
+grids=OSTN15_NTv2_OSGBtoETRS.gsb
# ETRS89 to OSGB1936
<7709-3D-Reverse>     -t0 +proj=pipeline \
+grids=OSTN15_NTv2_OSGBtoETRS.gsb +inv \
+grids=OSGM15_GTX_OSGBtoGRS80.gtx \
The only difference between the two is the reverse order and swapping the
+inv and 'no inv blanks' on the end of each line. I'm wondering if I need
two separate transformations?
If not is it a sensible future development? +init=<...> +reverse ?
Steve
Sent from: http://osgeo-org.1560.x6.nabble.com/PROJ-4-f3840930.html
