[Proj] Pipeline +init files, inverse
Kristian Evers
kreve at sdfe.dk
Wed Feb 21 13:35:15 PST 2018
Steve,
> On 21 Feb 2018, at 22:18, stevejking <stevejking at talktalk.net> wrote:
> Is it possible to use a +init pipeline file in reverse?
Yes. Well, mostly anyway. As long as a reverse path through pipeline exists. Some projections are only defined in the
forward direction, but that is not a problem for you here.
Below I assume you init-file is called “transforms”. You have several options:
1. Do an inverse transformation with cct:
cct -i +init=transforms:7709-3D
2. Reverse the pipeline by using a global +inv flag:
<7709-3D> +proj=pipeline +inv \
+step +proj=tmerc +lat_0=49 +lon_0=-2 +k=0.9996012717+x_0=400000 +y_0=-100000 +ellps=airy +inv \
+step +proj=vgridshift +grids=OSGM15_GTX_OSGBtoGRS80.gtx +inv \
+step +proj=hgridshift +grids=OSTN15_NTv2_OSGBtoETRS.gsb
Note the “+inv” in the first line. Any parameters specified AFTER proj=pipeline and BEFORE the first +step are global
and are added internally to each individual step in the pipeline. This is often useful for ellipsoid specification for instance.
If you +inv a step that is already +inv’ed you effectively get a double-negation which is just the forward operation. This
works for any number of +inv’s. An odd number of +inv’s results in a reverse step, and even number results in a forward
step.
3. Create a reverse entry that self-references the init-file:
<7709-3D_reverse> +proj=pipeline +step +init=transforms:7709-3D +inv
You probably just want to go with the first option, but depending on your use case 2 and 3 can be useful as well.
/Kristian
> For example, with some explanation from Kristian, I now have two
> transformations:
> # OSGB1936 to ETRS89(2)
> <7709-3D> -t0 +proj=pipeline \
> # ETRS89 to OSGB1936
> <7709-3D-Reverse> -t0 +proj=pipeline \
> +grids=OSTN15_NTv2_OSGBtoETRS.gsb +inv \
> +grids=OSGM15_GTX_OSGBtoGRS80.gtx \
> The only difference between the two is the reverse order and swapping the
> +inv and 'no inv blanks' on the end of each line. I'm wondering if I need
> two separate transformations?
> If not is it a sensible future development? +init=<...> +reverse ?
> Steve
> Sent from: http://osgeo-org.1560.x6.nabble.com/PROJ-4-f3840930.html
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
More information about the Proj
