[Proj] Pipeline +init files, inverse
Thomas Knudsen
knudsen.thomas at gmail.com
Wed Feb 21 13:45:04 PST 2018
use
+init=blabla +inv
For cct, there's also the -I switch:
cct -I +init=blabla
/Thomas
2018-02-21 22:18 GMT+01:00 stevejking <stevejking at talktalk.net>:
> Is it possible to use a +init pipeline file in reverse?
> For example, with some explanation from Kristian, I now have two
> transformations:
> # OSGB1936 to ETRS89(2)
> <7709-3D> -t0 +proj=pipeline \
> +step +proj=tmerc +lat_0=49 +lon_0=-2 +k=0.9996012717
> +x_0=400000 +y_0=-100000 +ellps=airy +inv \
> +step +proj=vgridshift
> +grids=OSGM15_GTX_OSGBtoGRS80.gtx +inv \
> +step +proj=hgridshift
> +grids=OSTN15_NTv2_OSGBtoETRS.gsb
> # ETRS89 to OSGB1936
> <7709-3D-Reverse> -t0 +proj=pipeline \
> +grids=OSTN15_NTv2_OSGBtoETRS.gsb +inv \
> +grids=OSGM15_GTX_OSGBtoGRS80.gtx \
> The only difference between the two is the reverse order and swapping the
> +inv and 'no inv blanks' on the end of each line. I'm wondering if I need
> two separate transformations?
> If not is it a sensible future development? +init=<...> +reverse ?
> Steve
> Sent from: http://osgeo-org.1560.x6.nabble.com/PROJ-4-f3840930.html
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20180221/22d965ef/attachment.html>
More information about the Proj
