[Proj] PROJ 5.0.0RC5
Marco Atzeri
marco.atzeri at gmail.com
Sat Feb 24 09:43:51 PST 2018
On 24/02/2018 18:09, Sebastiaan Couwenberg wrote:
> On 02/24/2018 05:59 PM, Marco Atzeri wrote:
>> on cygwin 64 bit it passes most of the tests, except
>> Reading file
>> '/cygdrive/e/cyg_pub/devel/proj/prova/proj-5.0.0-0.5a.x86_64/src/proj-5.0.0/test/gie/4D-API_cs2cs-style.gie'
>> proj=latlong nadgrids=nzgd2kgrid0005.gsb ellps=GRS80
>> Invalid operation definition in line no. 55:
>> (null) (errno=PJD_ERR_UNKNOWN/0)
> This is a known issue, see:
> https://github.com/OSGeo/proj.4/issues/819
> The fix has been merged:
> https://github.com/OSGeo/proj.4/pull/820
> Kind Regards,
> Bas
Thanks Bas,
with that fix I see only one failure
Reading file
'/cygdrive/e/cyg_pub/devel/proj/prova/proj-5.0.0-0.5a.x86_64/src/proj-5.0.0/test/gie/more_builtins.gie'
pj_cart_selftest fails with 64
total: 44 tests succeeded, 4 tests skipped, 1 tests FAILED!
Not sure if this is due to test without datumgrid
Regards
Marco
More information about the Proj
